Sharing variable between two robots multimove
Simple question but
I have two robots on multimove system. I want to share the variable speed between the two robots (same parameter)
How to proceed ?
Robotstudio tall me all the time it doesn't know "pers" variable from the other robot ..
Here below some example with toto string
Thank you
Regards,
  • you need to declare it in both tasks the same. each variable in its own task.
