Screenmaker and Load/Unload Modules
daniel72
daniel72
edited September 2020 in UpFeed
if there are references in the Screen Maker to variables that are declared in modules that are reloaded with Load / Unload, an exception error occurs when the screen is called after the modules have been reloaded (the variables are available in all modules and have the same name but different values)
You need to copy all of these variables after loading the module into variables in modules that are always available and set the references to these variables in order for it to work.
