Per Svensson's "SC Extended Motion" gives error in RS2020.2, help! (RSPAG included)
HZimmer
I opened up one of our old station in RS2020.2 which used the "SC Extended Motion" Add-in which was created by Per Svensson back in 2013. Unfortunately, that feature no longer seems to work in RS2020.2. I replicated the bug/error in a stripped station. Please see the attached *.rspag and screenshots of the errors that I get.
Is there any way to get the SC working again? A "dirty fix" would also be much appreciated to just be able to revive our old project for now, but would it not make sense to add this as a standard component in the SC library? We would definitely use it frequently also for our new projects.
Regards
Regards
- 38 AppStudio
