Import CAD geometry not working
Hi everyone,
I have a question regarding the RobotStudio SDK. I am trying to import a CAD-file. I used the examplecode (https://developercenter.robotstudio.com/api/robotstudio/articles/How-To/Geometry/ImportCADFilesExample.html) adjusted for my folders etc.
One part in the code is obsolete according to VisualStudio. This is the part I am talking about:
            if (station.GraphicComponents.TryGetGraphicComponent(gc.Name, out gc))
               station.Selection.Add(gc);
The "station.Selection.Add(gc)" part is obsolete.
I can't find the code to replace this and if I comment it out and I open the rslib created by the build nothing apears.
Does anyone have an example code that works for me, or guide me in the right direction.
With Kind regards,
Nick
  • dnilsson
    dnilsson
    edited November 2020
    You are right,
    the command is obsolete please use ABB.Robotics.RobotStudio.Selection.SelectedObjects instead.
          ABB.Robotics.RobotStudio.Selection.SelectedObjects.Add(gc);
    Daniel
  • Gustaffson
    Hi Daniel,
    Your sugestion works however the imported model still does not apear when I build the solution and open the rslib file that is generated. Is there something that I'm missing? When I disconect the smartcomponent from the libary in RS and edit the component, there is no import stated.
    This is the code added to the CodeBehind.cs:
           private static void ImportCADFiles()
                Project.UndoContext.BeginUndoStep("Import CAD Files");
                try
                    Station station = Station.ActiveStation;
                    // The file to be loaded.
                    // NOTE: Be sure to change this to an existing file name!
                    String fileName = @TestModel.step; (TestModel.step is written with quotation marks befor and after but they don't show up here)
                    // Check if the file exists.
                    GraphicComponent gc = null;
                    if (File.Exists(fileName))
                        // Load the CAD file.
                        gc = Part.Load(fileName);
                        // Set the name of the GraphicComponent to the file name.
                        gc.Name = Path.GetFileNameWithoutExtension(fileName);
                        // Add the GraphicComponent to the station.
                        station.GraphicComponents.Add(gc);
                        // Select the GraphicComponent.
                            Logger.AddMessage(new LogMessage("Body selected"));
                    else
                        // If file name does not exists, print a warning message.
                        Logger.AddMessage(new LogMessage("Could not load '" + fileName + "'!"));
                catch
                    Project.UndoContext.CancelUndoStep(CancelUndoStepType.Rollback);
                    throw;
                finally
                    Project.UndoContext.EndUndoStep();
    Is there something I need to add somewhere else in order to actually import the file in RS?
    With kind regards,
    Nick
