TCP checking
how can i check   the TCP that i created in robot thought robotsudio
  • If you wish to ensure you TCP is accurate, try reorienting the robot and visually inspect to see if your TCP is moving as you change orientations.
  • Create a new system using a backup. Make sure that the backup in restored into the new virtual controller. From the RAPID tab Synchronize to Station. Go to the Home / Paths and Targets /Your Controller/ T_ROB1/Tooldata. Cursor to your tooldata and right click. View / Examine. This will show you where your tcp is.
