How to create a do from error messege
Hey! I'm trying to create an output signal from an error from i / o. I sometimes get error 71058 (No contact whit I / O unit.) How can I create a trap or similar so I can get an output signal so the PLC can take care of it? it's an Irc5 Robot. Regards Per
Does the robot stop program execution with an error?Lee Justice0
yes it does.0
Well, if you have the controller set up with the system output for execution error, it ought to be turning that on.Lee Justice0
Use IError to interrupt on a defined error.
ex:Motion Supervision errorCONNECT intno1 WITH tColl;IError MOTION_ERR\ErrorId:=204, TYPE_ALL, intno1;0
- 40 AppStudio
