Controller Combination Unsupported - Task Required
IGWGLLM
Hello. I have downloaded RobotStudio to my work laptop (not networked) which I am using at my home address & have tried to install a Virtual Controller (as I have done before on networked PC's at work). In the 'Create Controller from Layout' option - once I have put a robot on the solution - it is looking for controllers in Robotware 7.0.4 & the next page shows an unsupported combination warning - the next page then continuously asks for Tasks. My colleagues also have this problem on their home based laptops. Any ideas please?
7 and up is omnicore controller, right? Is that what you are intending to create?Lee Justice0
I'll be honest - I'm not sure if it is omnicore. I just need to create a generic virtual controller to accompany the chosen robot (i have tried a few different IRB robots - same problem for all). This is purely for simulation as well.0
Go to the Addons tab and add some older Robotware6.xx versions, then try again using that robotware.Lee Justice0
That cured the problem - thank you very much
- I'm indebted to you! I will show this fix to my colleagues next week. Have a great weekend! 0 -
Great. You are welcome, and have a good one yourself.Lee Justice0
