CBC How to choose correct brake test interval?
does anyone know how to choose the correct brake test interval?
Thanks in advance
  • Hello,
    Your Risk Analyze should say you...
    It's depends your PLr.
    In most case, if your robot is closed into an enclosure, fixed to the ground and no one works nears, you don't have to do it because it may damage the breaks in time.
