Get a List of RAPID Routines via WebServices
MikeTT
Hello, I am trying to figure out the best way to retrieve a list of all the routines which exist in a RAPID module. In the PC SDK There was a Module class which had a GetRoutines() method which returned an array of Routine. I was hoping to find something similar in the Web API.
I was looking at using GET /rw/rapid/tasks/{task}/modules/{module}/routine but this requires row and column parameters which I am unable to supply as my front end application does not necessarily know about the existence of a routine prior to fetching them from RAPID.
Thanks in advance,
Mike
Thanks in advance,
Mike
I think this is what you want to look at:
https://developercenter.robotstudio.com/api/rwsApi/rapid_system_page.html
Which gives you all of the resources listed.
Daniel0
