Two Solenoid Mechanism in One Device
Hello, I'm trying to make a device that has two solenoid mechanism with two different actuators. I've have tried using 3 links and 3 joints to create the mechanism, but was given a "could not compile mechanism" error message. In this file https://gofile.io/d/PeOG42 I split the mechanism effect into two different Devices, which does not look very realistic. Some advice would be helpful.
