How can I exchange the warning message text when I switch to Automatic Mode
I have searched the program directory to find the message text string, but I wasn‘t successful. Can I replace the event message if the internal event signal AUTO1 changes its value?
I found an answer, which states that internal messages can not be changed.
https://forums.robotstudio.com/discussion/3668/message-box
What can I do to get another warning text?
Many thanks! Joerg
Joerg Vogel
Hochschule Hannover
University of Applied Sciences and Arts
IRB120 - RW5.61, RW6.13 - IRC5 compact
  • I bring this up to you, because it is still pending. I have already found the xml file which contains the message text. I need to know which privileges I need to exchange or update any file in directories containing language translation messages on the controller.
    Thank You all!
    Joerg Vogel
    Hochschule Hannover
