Design View ERRORs in RAB 5.08
oscar_f
Hello
since I moved on RAB 5.08 a working project, I cannot see anymore the design view. In the attached picture you can see the error massage from VStudio .Net 2005
BR
Oscar
BR
Oscar Ferrrato
Oscar Ferrrato
Hello
I believe this has to do with your FP SDK references.
First verify that the references you have added to your project point at RAB 5.08. (Open the cs.proj file in a text editor and check the references path)
Then make sure that the assemblies added to the Visual Studio Toolbox (to be able to use the Designer for the FP controls) are the same ones.
I hope this will solve your problem.
Ingela Brorsson
Software Engineer
ABB Robotics, Sweden0
