Synchronizing to controller cycle
mkatliar
mkatliar
edited January 2021 in RAPID Programming
Dear colleagues,
I want some code to be executed on each controller cycle. This is what I have in mind:
MODULE SomeModule
    PROC MyProc()
        WHILE TRUE DO
            ! do something important
            DoSomething;
            ! here I want to wait until the next controller cycle, how can I do that?
            WaitUntilNextControllerCycle;
        ENDWHILE
ENDMODULE
The thing is that I can't find a way in RAPID to wait for the next controller cycle; does it exist?
I could use WaitTime, but then a) it is not synchronized to the controller cycle; b) the time of the WHILE cycle will be equal to the wait interval + the execution time of DoSomething, but I want DoSomething to be executed at regular intervals.
What would you suggest?
  • I don't really understand your question, do you want this to be used as a continiously running proc while the robot is doing something else?
    If so, is this meant a second task?
    Yes you are correct -- this is supposed to be run in a separate "monitoring" task. The second task is the motion task.
  • Then you could do something like this;
    PROC main()
        Set StartMonitor; !StartMonitor is configured as a digital output
        WaitUntil StartMonitor = 0;
        DoSomething;
    PROC Monitor();
        WaitUntil StartMonitor = 1;
        Reset StartMonitor;
        DoSomethingElse;
