PC SDK SafeMove
SymAdil
Is it possible to load a safemove configuration file to an IRC5 controller with PC SDK?
I don't believe there is a way to do it through ABB API but if you have the time to poke around all the dlls im sure there will be something0
Thanks scottdf93 for your reply. I checked a while ago with ABB and apparently it would be possible by using Robot Web Services. I did not try it yet but based on the documentation it is possible.0
