prevent accidental system reset, in IRC5
I am taking your question to mean "accidental rapid reset", not merely restarting the controller. If that is correct, then you can set it up in the UAS grants and users.Lee Justice0
Hi yup, that is what i am referring, accidental system rest to default. How do i go about doing the UAS grants and users, any documents or links that I can have a look and study on it>?lemster68 said:I am taking your question to mean "accidental rapid reset", not merely restarting the controller. If that is correct, then you can set it up in the UAS grants and users.
Thanks
You will want to look at the operating manual for Robotstudio. There is a little information in the Operation manual, IRC5 with flexpendant.Lee Justice0
- 38 AppStudio
