Licensing issue using RobotStudio on VDI
Hi --
We're running Citrix XenDesktop for VDI. I've got a floating network license installed and activated, and I've got RobotStudio installed on our master image and configured to get its license from the server. No problems there -- it works fine. But when I deploy the image to the VMs, on first launch, it sees that the computer name is different and says it needs to reset the license storage. This requires admin privileges, which our students' accounts do not have. For the folks who have successfully deployed via a VDI platform, is there some trick I need to do to get it to work on the child VMs?
Thanks for any pointers you can give--
