TriggL/TriggLIOs/TriggEquip repeatability.
Fritz
Has anyone tested signal triggering repeatability with OmniCore or IRC5 ?
I'm planning to use it to trigger camera on-fly at speed arount 100-300 mm/s.
How mutch triggering position variance can be expected?
Thanks!
Thanks!
I have not tried to do this myself, but here is what the Technical Reference Manual has to say about the limitations regarding accuracy:
I would try some experiments and then post the results in here so we can all learn from your process.0
