Input a decimal-number on Screenmaker?
is there no posibility to set the accepted input value of a numeric field to decimal?
We don´t found a property to set integer or decimal - the application only accept integer values.
Best regards
mike
  • Why not round the value to the nearest integer?
  • Regarding NumEditor, there is an option to ShowDecimalPoint, which will allow you to input decimal numbers.
    "We're more aware of simple processes that don't work well than of complex ones that work flawlessly"
