write backup to network via 616-1 PC-Interface
daniel72
The task is to write a backup to a customer server using the UNC path with the siBackup system input.
With the option 614-1 FTP & NFS you can set up the Com-App and it works via FTP/NFS.
If you don't have the 614-1 FTP & NFS, but you have option 616-1 PC-Interface, there should also be a possibility to put the backup on the customer's server. How is the procedure here? What exactly is to be done? Its RW 6.11
Thanks Daniel
