Safety IO's to IRC5
PetrB
I need to wire few safety inputs into IRC5 (I have exchangeable tools and Safe move pro option. So when I change the tool, I need to change geometry of the tool in Safe move).
ABB recommends CI502-PNIO module, with safety IO's card's, but it's very pricey. I'm thinking about using Siemens safety PLC with safety DI card (1212FC + SM1226F-DI16) which is just couple hundreds bucks.
Any other ideas? Do I need other options then Safe move, to use Profisafe?
Cheers
Petr
You need one of the Profisafe communications options on the controller:
997-1 PROFIsafe F-Device 997-2 PROFIsafe F-Host&Device 0 -
Thanks Graeme. If I use option 997-2, does IRC5 have full Safety Host functionality, so I can use just Safety IO module (IRC5 would control safety communication)?
- 37 AppStudio
