Read PERS variable from YuMi using Robot Web Services 1.0
harsha
I am running RW 6.11.02 on YuMI (IRB 14000).
To read a PERS variable following command works on IRB 1200.
curl --digest -u "Default User":robotics http://localhost/rw/rapid/symbol/data/RAPID/T_ROB1/user/reg1
What would be equivalent for YuMi (IRB 14000) with RW 6.11.02 on left arm and right arm?
/rw/rapid/symbol/data/RAPID/T_ROB_L/user/reg1 doesn’t work.
Post edited by Nils Olofsson on
I moved the post to the Developer tools category.
What response do you get? I tested the same thing with postman and it works just fine.
—Nils OlofssonPC Software Support Engineer0
- 40 AppStudio
