Cant start 5.07 stations with 5.08
After installing RS 5.08, I found I could not start some stations that were created with 5.07. I get the message: RobVCFactory.Launch failed, hr=c0040702 One or more files in the system directory is corrupt and cannot be used when launching a VC.
Unfortunately, there is no way to guess what files are corrupt or missing. The system is an IRB6650_275_200_M2004. I have tried re-installing a 5.07 version of RW, but with no change in the error message or results.
I've got 6 - 8 stations saved that use this same system, and I don't want to have to recreate the thousands of targets and several hundred paths.
BTW - I did a install/repair of RS 5.08 because the RS Support Tool would crash every time I tried to run it. Now the log file only echos the dialog message or a VC timeout message.
The message indicates that something is wrong with the RW you use for the system. Are you sure that you re-installed the same 5.07 version that your system is created with?
ABB Robotics0 -
Thanks. That was the problem. It just took me a little while to find the RW version without the controller running.Jim Haglund0
- 364 IRC5
- 82 OmniCore
- 37 AppStudio
