socket communication?
I have robot with IRC5 controller with option:socket messaging,and I want the robot change it's path by read data from pc via socket. does the following code works? Thanks!
Module Socket
VAR socketdev temp_socket;
VAR socketdev client_socket;
VAR string received_string;
VAR num received_nX;
VAR num received_nY;
VAR num received_nZ;
SocketCreat temp_socket;
SocketBind temp_socket,"192.168.125.2",5000;
SocketListen temp_socket;
!waiting for a connection request
SocketAccept temp_socket , client_socket;
SocketClose temp_socket;
SocketReceive client_socket Str:=received_string;
X:=received_nX;
Y:=received_nY;
Z:=received_nZ;
SocketSend client_socket Str:="Hello client";
VAR num nX :=0;
VAR num nY :=0;
VAR num nZ :=0;
CONST robtarget pOffset:=[[1803.34,-515.97,1673.73],[0.000106,0.719759,0.694225,0.000419],[-1,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
MoveL Offs(pOffset,nX,nY,nZ),v150,fine,tCurrent;
ENDMODULE
- 37 AppStudio
