Create a Solution from RAPID Modules
Is there a way to create a RobotStudio Solution using RAPID modules? I have several indivudal modules which all go to the same robot, but no solution which allows me to view the robot in modeling or simulation.
I'm still new and learning ABB by going through the manuals and online tutorials.
  • Do you have a backup of the system? If you do you can create a station from the backup which will then load all relevant stuff in when correct.
  • lemster68
    lemster68 ✭✭✭
    Make your own solution which matches the real robot, then load those modules.
    Lee Justice
