No connection to the Omnicore control
WallE
Hello everyone,
I have a problem connecting my RS to an Omnicore control.
Connecting to RW6.xx controller is working.
Base Data:
Robot IRB 1100
Base Data:
Robot IRB 1100
RobotControl Version: 7.2.0
RobotOS Version: 3.0.0
FlexPendantSoftwareUpdate Version: 1.4.0
Robots Version: 1.2.0
Robotstudio Version 2021.1.2
APP
RobComCtrlServer.exe is running
RobNetScanHost.exe is running
1. Tested with and without Firewall
Laptop connect to Controller Port MGMT
Laptop Network Setting (Auto IP)
2. Tested with and without Firewall
Laptop connect to Controller Port WAN
Laptop Network Setting (Fix IP)
In this case , i can find the controller and select them.
Fault at 1 and 2:
APP
Fault at 1 and 2:
RobotStudio .NET exception: C0040403 : No response from controller.
Timeout
Base exception: RobApiException
Timeout
bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
bei RobotStudio.Services.RobApi.RobControllerConnection.<Connect>d__115.MoveNext()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
bei ABB.Robotics.RobotStudio.Controllers.ControllerManager.<AddController>d__43.MoveNext()
bei RobotStudio.UI.Controller.Commands.ConnectController.<TryConnect>d__2.MoveNext()
NetscanId:11
NetscanIdForDiagnostics:11
ControllerIP:192.168.125.1
NetscanAvailability:CtrlAvailable
PingResult:Success
Ideas to solve the problem
Thanks in advance
Thanks in advance
