CONNECT TRAP execution error
Dear ABB family,
I am trying to execute a trap/interrupt function and I get fallowing error, see photo below.
I think i declare de "CONNECT"in wrong place.
Can someone give me a tip how to o it properly?
Thank you a lot.
Selen Ersoy
Thank you a lot.
Selen Ersoy
Like the instruction error says, you cannot use the same variable name to connect with multiple traps. Create a unique variable name for each trap to solve the issue.1
@xerim I use already two different variabele intno1 and intno2 with digital signal R_HOLD, R_ManualHOLD
I still doesnt see it.0 -
I don't see where those variables are being declared, try setting it up like this
1 -
I declare those before proc main, under Module, like i declare my other variable.
So, should i declare thos in my main proic
I think you need to call IDelete on intno1 and intno2 prior to connecting them to the trap1
Like this:
IDelete intno1;
IDelete intno2;
CONNECT intno1 WITH HOLD;
CONNECT intno2 WITH ManualHold;
ISignalDI R_HOLD,1,intno1;
ISignalDI R_ManualHOLD,1,intno2;
1
- 364 IRC5
- 82 OmniCore
- 853 RAPID Programming
- 35 AppStudio
