Check Controller Status Error
jmf
Hello Everyone
Has anyone got any idea why RS will give the error "Move Along Path: Command failed. Check the controller status." when running a simulation?
The path is running correctly when it is loaded to the RAPID and simulation is started but when you synchronize to the station and want to run "Move Along Path" instruction, it directly gives the error.
See attached video for reference.
