Backup Failed - The system cannot find the file specified
neily04
Hi all,
I'm getting the above error when I try to back up using either the Jobs feature or just the back up option in the controller tab.
It doesn't tell me which file it cannot find so I'm not sure how to fix it.... Anyone had the same issue?
Cheers
Look in your sys.cfg to see if there is something like this:SYS:CFG_1.0:6:0::#BACKUP_RESTORE-IncludeDirAtBackup "Example"Lee Justice0
No there no sign of that in the sys.cfg but the problem has gone away after upgrading RS to 2021.2
