Abb screen maker password?
Dedex
I have one application. I developed with Screen Maker.
Can i put the password this application.
When application starts app will ask password?
Is it possible?
Best regards.
Is it possible?
Best regards.
It´s complicated, but you can use a method from C# .NET and add the parameters. The other alternative it´s use rapid code, but it´s difficult to hide the password routine.0
I do have a similar question, I want to secure only one page with a password, would this be simpler?
How can I edit the C#.NET methods in ScreenMaker? Do I need to use the EventsManager and ApplicationVarables? Or is it somehow possible to access the raw code?
mox117 said:[...] you can use a method from C# .NET and add the parameters [...]0
