Deactivate Warning RunRoutineButton
Hi there,
on my ScreenMaker UI i have some RunRoutineButtons. If I click the RunRoutineButton the warning "The robot may move. Do you want to contiunue to run the routine?" apperars. Is it possible to deactivate this message because i want to start routines without moving? I can´t use a trap Routine instead because the Controller is in manual mode.
Thanks for your help!
