Setting IRC5 for direct communication to CP 600 HMI
pacijent
pacijent ✭✭
Hello to all, I have created HMI project as instructed using driver for direct TCP/IP communication to IRC5. I have used LAN port to connect IRC5 to HMI with running project. I have defined IP address of HMI (192.168.1.10), and IRC5 address in HMI control builder project (192.168.125.1), but I'm not getting read/write of IOs. In IRC5 communication setting I added LAN address of HMI but I'm not sure if this is proper way, anyhow this setup doesn't work. Do you have any suggestion how IRC5 has to be configured in order to communicate with ABB CP 600 HMI.
