Reference error in navigator
I have a robot with navigator and bullseye option but if i try to use SearchSPL or Measure_1D the controller comes with error when loading the modul.
130 : Reference error : Reference to unknown procedure SearchSpL
It does the same in RSO and RS.
It seems that i dont have the priviliged to use the command. The key is not viatuel but bought from ABB
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Klaus
    Klaus ✭✭
    I have found the error my self.
    If you add navigator to an existing system you should not make the system from a backup. Then you overwrite the proc file that navigator makes during installation
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • I had this same problem. I found that the root cause was in the sys.cfg there are several lines that load the navigator option. You can add those lines instead of loading things 1 at time.
    The image below shows the 3 lines that are missing when a backup is loaded in.
