Path Offset generates Tool coordinate system error 50058
Dear All,
I am executing a path with a welding tool running as vertical as possible (parallel to Z World). The program use to execute with no errors until I introduced the Path Offset corrector aiming to adjust Z-axis only. Once Path Offset was introduced, the robot moves normally until aligning the tool with Z (as expected) and then returns the following error:
Description
Actions
50058: Tool coordinate system error
Description
The z-direction of the tool coordinate system is almost parallel with the path direction.
Actions
Change the tool coordinate system to achieve at least 3 degrees deviation between z-direction and path direction.
Since my process MUST keep the tool vertical (Z-tool parallel to Z-World), solve it by introducing intentional 3 degrees error deviation seems the wrong approach.
Is there a way to overcome this problem? Can this be a bug since removing the corrector function the program executes with no error?
Your advice is very much appreciated.
