IOSystem GetSignal Parse Properties
Dear All, I`m kinda slipping on this and need some tip from the experts:
I`m developing an AddIN Button to parse IO`s properties from RS (-Name, -Type, -Value, -DeviceMapping);
I can read all but last one by e.g.:
Signal signal1 = controller.IOSystem.GetSignal("diMotorOn");
string Name = signal1.Name; (I know redundant =S, just as example)
string Type = signal1.Type.ToString();
float Value = signal1.Value;
int mapPosition = signal1.?
Ok, I can Query those values from EIO.cfg after doing a backup and compare them with my standard sequence but there maybe is some shortcut from IOSystem?
I need to make sure IO`s are located in the right sequence bit (standard).
Thank you in advance
Edson
Best Answer
  • saitoevc
    saitoevc
    Answer ✓
    Ok, I`ve found my answer.
    If you are interested on knowing:
    using ...Controllers.ConfigurationDomainl;
    then able to use this:
    .ConfigurationDataBase myconfigDB = mycontroller.configuration;
    string[] myPath={"EIO","EIO_SIGNAL","diMotorOnStart","DeviceMap"};
    .string myData=myconfigDB.READ(myPath);
    Ok, so what? this is already in ABB WebSite: Configuration domain (robotstudio.com)
    Right! But here is my tip:
    RS says "Device Mapping" in Signal Config and ABB Website says: "UnitMap" for Unit scan.
    As I`m tryna scan from RS, EIO.cfg label is "DeviceMap" :wink:
    Cheers from Italy
    Edson
