Why can't I Define tooldata with FlexPendant?
I've been using IRC5 for a while now, but I'm stuck on some annoying problem. I cannot Edit anything from tooldata (and by the looks of it wobjdata also), all options are greyed out. Standard data (BOOL for example) can be edited. I have the Edit Rapid Code grant which states I can calibrate Frames. Must missing something silly but I have no errors nor do I have any messages telling me what is missing to be able to calibrate Frames.
Might I mention that I have SafeMove installed which is a first for me. Only error was syncrhonization which I did but still no success.
Any idea?
Any idea?
Best Answer
Check the declaration properties of the module in which they are declared. If it has NOVIEW or VIEWONLY properties you cannot alter the data.Lee Justice1
Try logging in as a safety user as editing the tooldata would affect any SafeMove zones using it.0
I'm currently using this type of login which I named Programmer:Backup and saveGives access to perform a backup and to save modules, programs and configuration files. The grant gives full FTP access to the current systems BACKUP and TEMP directory.CalibrationGives access to perform the following: Fine calibrate mechanical unit, Calibrate base frame, Update/clear SMB data. Note! Frame calibration (tool, wobj) requires the grant RAPID code. Manual offset of mechanical unit calibration data and loading new calibration data from file require grant Modify configuration.Modify configurationGives access to modify the configuration database, that is load configuration files, change system parameter values and add/delete instances.Modify controller propertiesGives access to set controller name, controller ID, system clock and WAN IP configuration.Delete logGives access to delete messages in the controller Event Log.Read access to controller disksGives external read access to controller disks. This grant is only valid for explicit disk access, for example with an FTP client or the File Manager of RoboStudio Online. It is possible, for example, to load a program from SYSTEM_PARTITION without this grant.Write access to controller disksGives external write access to controller disks. This grant is only valid for explicit disk access, for example with an FTPclient or the File Manager of RoboStudio Online. It is possible, for example, to save a program to the controller disk or perform a backup without this grant.Full accessThis grant includes all controller grants, also new grants added in future RobotWare versions. The grant does not include any application grants, nor the "Safety Controller configuration" grant.IO write accessGives access to perform the following: Set I/O signal value, Set signal as simulated and remove simulation, Set I/O unit and bus as enabled/disabledKey-less mode selectorUnlock key-less mode selector.Lock Safety Controller configurationLock/unlock safety configurations. Lock/unlock Key less mode switch. This grant is not included in the "Full access" grant.Modify current valueGives access to modify current value of any RAPID variable. The grant is a subset of grant "Perform ModPos and HotEdit".Program debugGives access to perform the following: Move PP to routine, Move PP to cursor, HoldToRun, Activate/deactivate RAPID tasks, Request write access from the FlexPendant, Enable/disable non-motion execution.Edit RAPID codeGives access to perform the following: Modify code in existing RAPID modules, Frame calibration (tool, workobj), Commit ModPos/HotEdit positions to current values, Rename programExecute programGives access to perform the following: Start/step program (stop is always allowed), Move PP to Main, Execute service routinesLoad programGives access to load/delete modules and program.Perform ModPos and HotEditGives access to perform the following: Modify or teach positions in RAPID code (ModPos), During execution modify positions in RAPID code single points or as a path (HotEdit), Restore ModPos/HotEdit positions to original, Modify current value of any RAPID variable.Remote loginA user with this grant can request FlexPendant to login as another user.Remote restartGives access to perform system restart and main computer shutdown from a remote location. No grant is required to restart the system via a local device, as for example the FlexPendant.Restore a backupGives access to restore backup and perform "Revert to last auto saved".Revolution counter updateGives access to perform revolution counter update.Commissioning modeGrant for changing the safety controller to commissioning mode.Safety Controller configurationGives access to perform a configuration of the Safety Controller. Only valid for the PSC-option. This grant is not included in the "Full access" grant.Safety servicesLoad and validation of safety configurations. Change between Service, Commissioning and Active mode.Software synchronizationActivate Software Synchronization for the Safety Controller.Decrease production speedGives access to decrease speed from 100% in Auto mode.Administration of installed systemsGives access to perform the following: Install new system, Reset RAPID, Reset system, Start Boot Application, Select and Delete System, Install system from device. This grant gives full FTP access, that is, the grant gives the same rights as Read access to controller disks and Write access to controller disks.Update a RobotWare systemGives access to perform an update of a RobotWare system.Manage UAS settingsGives access to read and write the UAS configuration, that is to read, add, remove and modify UAS users and groups.
As you can see, I have Safety services, Safety Controller configs and Lock Safety controller. Is that what you mean by logging in as safety user? I tried all safety controller modes but no success. My next step is to load my tools in the SafeMove app. I'll let you know if I have any success0 -
No success when defining tools in SafeMove. Still that same problem. Might I add that I cannot direct edit tooldata/wobjdata neither as if I couldn't do any calibration from the FlexPendant...0
Update: Had deleted the BASE sys file which contains tool0, wobj0 and load0 as PERS to adapt thir name to our nomenclature (tdTOOL0, wdWOBJ0, etc.) and declared them as CONST in order to prevent write access from any user. Deleted all that and reloaded a virgin BASE.sys which contained the tool0, etc. Still no success0
Exactly. Just found out the hard way... We can write access with program with VIEWONLY but not with FP. I knew it was something silly...! Thank's lemsterlemster68 said:Check the declaration properties of the module in which they are declared. If it has NOVIEW or VIEWONLY properties you cannot alter the data.0 -
You are welcome.Lee Justice0
- 84 OmniCore
- 37 AppStudio
