Reading RAPID variable in realtime
Is it possible to read value of a RAPID variable (numeric type) in real time? A PLC or similar device with a real time bus communication such as EtherCAT may be used to read the values. Read frequency will be around 1 kHz (cycle time of 1 ms or less)
