Question on StateMachine Add-In 1.1 Usage
chuacb
hi,
I have installed the StateMachine add-in 1.1 into RobotStudio and everything is well after installation.
Then I followed Application Manual to trigger the input RUN_RAPID_ROUTINE, nothing happened. On the operator window, the message remains the same, scrolling
"T_ROB1 -> [main]: Idling ..."
Not sure where I am doing wrong, appreciate a kind advice on the usage on the input triggers for the StateMachine.
Thank you.
Thank you.
