Smart Componente cut two Bodies
Spawn14
I have another good question!
If i cut two Bodies in a smartcomponent of the Robotstudio SDK- I use:
>Body[] cut = BodyMain.Cut2(BodyTool);<
and then add the result Body to an existing Part, the Body appears somewhere in space.
How or where do I have to edit the position of the Resultbody?
The question "Do you want to update the position" always comes up in Robotstudio if you move a Body from One Part to another. What happens in Robotstudio when you say "No update"? Thats the answer I need!
thx for every answer
If you answer "No update" then the body stays where it is position wise only the part it is part of is updated.0
