The type or namespace name 'Modules' could not be found
Jorge
Hello, I trying this example from flexpendan sdk, And I got this error while trying to compile:
Error 1 The type or namespace name 'Modules' could not be found (are you missing a using directive or an assembly reference?) C:\Users\W7\Documents\Visual Studio 2008\Projects\TpsViewIRC5WartsilaApp\TpsViewIRC5WartsilaApp\view.cs 184 18 TpsViewIRC5WartsilaApp
This is the exampled extracted from SDK help
private int CountRoutines(Controller c)
int result = 0;
Task[] tasks;
try
tasks = c.Rapid.GetTasks();
Modules modules;
// Iterate tasks
foreach (Task t in tasks)
// Get all modules of the task
modules = t.GetModules();
Routines routines;
foreach (Module m in modules)
// Get all routines of the module
routines = m.GetRoutines();
result += routines.Lenght;
catch (GeneralException ee)
// TODO: Add error handling
catch (System.Exception ee)
return result;
int result = 0;
Task[] tasks;
try
Modules modules;
// Iterate tasks
Routines routines;
return result;
Any Idea?
Thanks for help
Jorge Turiel
Hi Jorge, the data types Modules and Routines don't exist.
The methods getRoutines and getModules return an array.
Here is the correct code.private int CountRoutines(Controller c){int result = 0;Task[] tasks;try{tasks = c.Rapid.GetTasks();Module[] modules;// Iterate tasksforeach (Task t in tasks){// Get all modules of the taskmodules = t.GetModules();Routine[] routines;foreach (Module m in modules){// Get all routines of the moduleroutines = m.GetRoutines();result += routines.Length;}}}catch (GeneralException ee){// TODO: Add error handling}catch (System.Exception ee){// TODO: Add error handling}return result;}Best regards,
//U.0 -
Thanks for your help, It's works/JJorge Turiel0
- 84 OmniCore
- 37 AppStudio
