Skill creator TOOL_TYPE
I created a block with skill creator which reproduces the MOVEJ.
But I have a problem if I add a tool manually from Program DATA it does not appear in the drop-down choice of the tool.
While on the original movement block it appears.
Did I forget something when creating my block?
  • At the moment this is true - you need to add the tools by name. It will be fixed in the next release.
