proc argument
Hi!
Please tell me why it works with num, but does not work with string?
it work:
PROC main
    test 1;
    test 2;
PROC test (num x)
    IF x = 1 THEN
    ELSEIF x = 2 THEN
    ENDIF
it will be error:
PROC main
    test first;
    test second;
EMDPROC
PROC test (string x)
    IF x = first THEN
    ELSEIF x = second THEN
    ENDIF
Best Answers
  • Maxim Riabichev
    edited January 2022 Answer ✓
    Don't use "test" as proc identifier. It looks like it's reserved.
    This syntax seems to work:
       PROC abc(string x)
            IF x="first" THEN
            ELSEIF x="second" THEN
            ENDIF
        PROC abcd(num x)
            IF x=2 THEN
            ELSEIF x=3 THEN
            ENDIF
    Maxim Riabichev
    PC Software Support Engineer
  • lemster68
    lemster68 ✭✭✭
    Answer ✓
    Also your syntax when calling:
      Test "first";
    To indicate that it is passing a string into the procedure.
    And, same as Maxim's example, you need to have the quotation marks to indicate string data type:
    IF x = "first" THEN
    UNLESS it is the name of an already declared string data.
    Lee Justice
      Test "first";
    IF x = "first" THEN
    The quotation marks. Here's what I missed when working with string. Thanks!
    p.s.
    I used "test" just for the sample code
