Controller does not detect the USB device
Sahcha
Hello all,
I am trying to connect a USB device to my S4C+ controller. However, nothing shows up in directories when I connect the device. The only directory it shows is the hd directory. In the controller that I have , the floppy disk is converted to an USB port.
I tried converting the USB into a floppy disk emulator and then connected it to the device. Still the same results.
I am trying to make a backup copy of the controller on a USB device.
Please help me out.
Thanks,
Sean
Please help me out.
Thanks,
Sean
Contact your local (US if you're in Buffalo, NY) and request the USB installation kit instructions.
There are directions on how to use the device once installed.0 -
Thank you!
I was able to connect the USB. It turned out , the USB had to be first formatted as a floppy drive.0
