problem viewing paths in rs studio
I am having an issue viewing paths in robot studio after I load a module, for some reason in elements it doesn't show any of my moves, does anyone know what could be causing this?
Thanks in Advance,
What kind of moves does you have in your module.
By default RS only supports
MoveL
MoveJ
MoveC
all others need to be defined in the Instruction Manager so that RS knows how to handle themPer Svensson
Consat Engineering0 -
I only have those moves and I useually don't have this issue with other programs but for some reason I still can't see the paths.
Thanks again,
dh_custompak2010-05-30 04:37:30Dustin0 -
Do you get any errors when you do a sync to station (log window)If you post the module I could have a look at it.Per Svensson
I had this problem too at one point.
I was able to work around by defining all the used datatypes (welddata, weavedata, speeddata, seamdata, etc.) that are used in the Rapid instruction via the teachpendant.
However, I was never able to successfully bring in searches.
DanS2007-5-22 19:23:280
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 300 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 336 IRC5
- 67 OmniCore
- 828 RAPID Programming
- 12 AppStudio
- 107 Collaborative Robots
