EGM Error Code 41822 No data from the UdpUC device
in IRC5
Hello everyone,
I am encountering a problem with the EGM package using the .NET platform.
To be specific, I have tested the data streaming, and It works just fine, but the motion guidance test is failed with no package is sent to the robot controller.
As checked using Wireshark, I found that the package actually is sent to the robot controller. I just wondering if the network transmission frames are in order of receiver and sender sockets as KUKA.RSI option, which has the same function and implementation as EGM and Is there any possible mistakes in the complied message.
Here are some pictures of the RAPID code and also the compiled messages from the Protobuf.
Any helps would be really appreciated. Thank you.
Best Regards,
Huy
- Wireshark with ABB
- Wireshark with KUKA
- Compiled messages (above is a sent package to the robot, below is the received package)
- Rapid code
Best Regards,
Huy
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
- 107 Collaborative Robots
