Routine File (Help)
Hello everyone. I want to perform an action on a Routine file. I want the Robot to stop automatically when a signal that I specify in the Routine File (Across the Whole Loop) does not output. For example, with a switch that sends a digital output, I want the Robot to stop when the air outlet is insufficient. How can I do that?
  • You could program an interrupt.  Or you could make it a system input which would make it stop.
    Lee Justice
  • Firstly, thank you. I don't know exactly how to do it. Can you share an example or manual on this?
  • The easiest for you would be the system input.  Read up on that in the System parameter manual.
    Lee Justice
  • Thanks.
