How to run MTPP 5.08 in RW5.09 [MachineTending PowerPac]
I found out why my MTPP will not run. It is because I have RW 5.09 installed on my computer. It was released a couple weeks ago. When selecting default templates RW 5.09 is used. MTPP apparently will not run with 5.09. This must be corrected immediately. The work around is to start with an Empty station. Use System builder to create the System with RW 5.08 as the software. After the system is built, add the System (F4) to the view. You may then use MTPP.
