error handler timeout 41773 in event log
NickCan
hello!
is there a way to turn off the logging of this warning in the event log? :
41773: Timeout
41773: Timeout
Description
Task: T_Camera.
A timeout interrupted the execution of instruction using camera Cam1.
Program ref: /mCamera/pCamTriggerGroup6/CamGetResult/1002.
every second I get this warning so my event log is full of it... totally useless for me.
that error came from this part :
!REquest image until one Pattern is found
While Cam1Result1.val1=0 DO
CamReqImage cam1;
WaitTime 0.5;
CamGetResult cam1,Cam1Result1\MaxTime:=0.2;
ENDWHILE
______
and this is the error handler ! Error handler for Camera get Result TimeOut
ERROR
IF ERRNo=ERR_CAM_MAXTIME THEN
TRYNEXT;
ENDIF
Add "SkipWarn" instruction to your Error Handler. It will not add the error to the Event Log.
thanks jmf!!
