Share variables between 3+ RAPID Tasks
Kappa95
Hello community,
I am working with an IRB 2400/16 and I am developing an applications which uses 3 tasks: T_PAR, T_EXTRUDER, T_ROB1.
T_PAR is a tasks which communicates via socket for getting a data message and save the message in 8 variables: 6 for the pose and 2 for speed and extrusion parameter.
T_EXTRUDER: takes the extrusion parameter from the reading in T_PAR and makes a communication socket with another device.
T_ROB1: Takes the pose data from T_PAR and executes the motion.
Question: the variables are saved in SYSTEM module and shared installing the module in the autoloading. But they are only shared between T_PAR and T_EXTRUDER. Is it normal?
Thank you in advance
Fede
Fede
Best Answers
The Data must be declared as PERS in all tasks which must share it.Lee Justice0
Yes as long as you declare data as PERS and with same name you can read/write the data in all tasks.Kappa95 said:But with PERS the data can be modified between all tasks?
I usually only to declare the "initial value", the :=, in one of the task, e.g.
T_ROB1: bTest:=TRUE;
T_ROB2: bTest;
T_ROB3: bTest;
David
Swedish freelance ABB robot programmer0
But with PERS the data can be modified between all tasks?0
yes-----------------
David
Swedish freelance ABB robot programmer0 -
This is not the case when the module is installed shared, all data in an installed shared module are shared between tasks. Even data declared as VAR.lemster68 said:The Data must be declared as PERS in all tasks which must share it.
//Markus Näslund1
- 361 IRC5
- 79 OmniCore
- 853 RAPID Programming
- 30 AppStudio
