Create file in a FlexPendant SDK View
Toni
I'm trying to create a text file when I press a control Button in my FlexPendant view. The text file is only for test and must have inside "Hello TXT".
Please any suggestions?
Use the .Net Compact Framework functionality in System.IO to create a text file and then use RAB functionality to copy over to the robot file system if that's where you need it to be.
Russell Drown0
