IoT Gateway 1.1 OPC-UA Application Certificate
We have an issue with an application not able to connect to IoT Gateway due to an issue with the DNS name stored in the Application Certificate.
When trying to create a new certificate -> Error "The CertificateGenerator utility is not installed"
When trying to import a certificate -> IoT Gateway configuration application hangs
Can you provide the information on :
1. IoT Gateway version and the build number
2. RW version and build
kindly attach the screen shorts of the error that you got and and also the reproduction steps.
—Doyel JosephPC Software Support Engineer0 -
I meet the similar problem, the certificate expired and when trying to create a new certificate -> Error "The CertificateGenerator utility is not installed"
1.2.1.0
6.14.00.01
Thanks and BR.0
- 37 AppStudio
